plug gap on NGK TR6??? - LS1TECH
Thread Tools Search this Thread
Old 08-13-2004, 10:22 PM   #1
Default plug gap on NGK TR6???
Anyone know what to gap these at for 75- 150 wet shot???THANKS
matty169 is offline   Reply With Quote
Old 08-13-2004, 10:25 PM   #2
next's Avatar
It makes a slight difference with how your car is tuned, but .038 should work fine.
next is offline   Reply With Quote
Old 08-13-2004, 10:27 PM   #3
Default thanks
Thank you for quick reply
Old 08-13-2004, 10:31 PM   #4
next's Avatar
No problem, hope everything works and it makes you
Old 08-14-2004, 12:45 AM   #5
Honez's Avatar
.035 for mine
Honez is offline   Reply With Quote
Old 08-14-2004, 12:47 AM   #6
Cheatin' Chad's Avatar
.036 for me. Stock timing, 150 wet on 93 octane. No KR while spraying.
Cheatin' Chad is offline   Reply With Quote
Old 08-14-2004, 11:02 AM   #7
Turo's Avatar
i went .038, works great on a TNT 100 wet shot
Turo is offline   Reply With Quote
Old 08-16-2004, 08:15 AM   #8
ccajun4real's Avatar
Quote:
Shooting TNT 100 Wet also. Just got my TR6 today. Will tray .038. Thanks
ccajun4real is offline   Reply With Quote
Old 08-18-2004, 04:55 PM   #9
Stock gap is .060 i gapped ten less at .050 do i need to regap down to .035 or .038 on NOS 100 dry shot or will it not really make a difference
Lt1BadBoy is offline   Reply With Quote
Old 08-19-2004, 08:16 PM   #10
Default .060 gap spray
Ive sprayed 100 h.p. T.N.T. with stock .060 gap with no problems for the last two years.
quick curt is offline   Reply With Quote
Old 08-23-2004, 05:34 AM   #11
PREDATOR-Z's Avatar
Gap is only shortened as a preventative method to illiminate plug "blow off" under extreme cylinder pressures and therefore missfires.
Anything up to 150 should be between .038>.042
I gapped mine .040
PREDATOR-Z is offline   Reply With Quote
Old 08-23-2004, 10:46 AM   #12
GTP4UNME's Avatar
I have mine gapped at .040 and have a slight surging feel while I'm spraying sometimes (TNT F1). I thought it might be from "blow off", but if people have run with the stock gap without a problem I'm guessing thats not my issue.
GTP4UNME is offline   Reply With Quote
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
