Bottle heater Question?
Old 04-07-2005, 05:34 PM
JRracing's Avatar
Default Bottle heater Question?
I have a NX heater, & the silinoid that mounts on the bottle will not fit with were i have the thing mounted.Witch is in the spare tire well. So can i wire the heater direct to a switch & just turn it on, let the presure come up then turn it off. I know i would have to stand there and watch it, then turn it off.But is this ok to do. I don't want to have to relocate the bottle.
Old 04-07-2005, 06:48 PM
jd13's Avatar
Yeah you'll be fine doing that.
Old 04-07-2005, 07:07 PM
viper9403's Avatar
Yeah I did the same to mine, just make sure and watch it.
Old 04-07-2005, 08:21 PM
860 Performance's Avatar
Woah, before you do that....
The pressure switch dosen't need to be mounted at the bottle like the instructions say. You can place the flowthrough manifold/ pressure switch which comes with the kit, where the nitrous solenoid attaches to the main feed line. You probably have room there.
Also, most toggle switches will not last long flowing 240W (18A). If you decide to eliminate the pressure switch at least install the relay like the instructions say. And be sure to use heavy wire and an inline fuse between the black wire on the relay and the battery.
Old 04-07-2005, 08:24 PM
slow's Avatar
ditto.
Many of the installs I do, I mount the pressure sensor on the front by the noids, thats one less wire to run back there, and 2 less things to disconnect when your changing bottles.
note: this is ONLY for vehicels that keep the bottle on whenever the heater is running </disclaimer>
Ryan
Old 04-08-2005, 10:26 AM
JRracing's Avatar
Good info thanks.
Old 04-10-2005, 10:26 PM
Kolk1's Avatar
Hmm, i have the 15 bottle with bottle pressure gauge, and auto bottle heater, and have no fitment issues in the spare tire well. i think thats odd.
Old 04-11-2005, 01:40 AM
JRracing's Avatar
Could I see some pics to get a new idea of how to do it. You could e-mail to rossjrss24@comcast.net
Old 04-11-2005, 01:20 PM
Kolk1's Avatar
Its kinda hard to tell, but im just using the one Taller bottle bracket, and its just bolted to the antenna mount. Under the hood its totally hidden, so i havent really spent much time cleaning up the wires in the trunk. But it fits, and all works. Also the wires from the Shock sensor, and speaker are still laying back there, so it looks alot worse than it actually is. The only part of the wiring i want to redo is the grounds. They work, but kinda shady.
Old 04-12-2005, 12:36 AM
JRracing's Avatar
Mine is down in there a little deeper & more horizontal, I might half to remount it. DAM IT! Maybe I should keep tring to adjust it. Thanks for the pics.
