Purging Questions
Purging Questions
I will be purchasing the dynotune purge system soon and am going to hard line my purge lines in to run to dual purges out my windshied my question is will i need to also purchase twin outlet kit or will I be able to use copper tubing to run my hard lines and just get a T fitting from a hardware store and run it that way.
Questions:
1. What tools,materials will I need to run copper hardlines
2. Is this hard???
3. Will I need to buy the dual outlet kit from dynotune?
Questions:
2. Is this hard???
LS1TECH Sponsor
All you need is a few parts from home depot. Simply bring the solenoid with you. You will need a 1/8" npt "T" and then some 1/8" NPT to compression fittings. Pick the flexible copper tubing you want to do and you will find the tubing and fittings you need at home depot!
Enjoy
Dan
Enjoy
Dan
