problems with my NX kit.....help please :(
i was at the track the other day and i had a full bottle but my nitrous was not working. i have an NX wet kit with a bottle heater, fuel pressure safety switch and a bottle opener. this is my problem........i will arm my nitrous and then stomp on the gas, it will hit in one gear and then when i shift...nothing. its like it just dies. i have it set on a WOT switch
any ideas as to what could cause this? all my fuses and **** are working fine, i checked it all out.
LS1TECH Sponsor
I would highly recommend a window switch also!
http://www.speedshop.org/store/Scrip...?idproduct=138
Dean
Dean
Closed ex-Sponsor Account
Originally Posted by mulletwearingtadrive
a window switch will be ordered soon but is there any other advice you guys could give me to troubleshoot this problem with my nx kit?
Our new dual window switch upgradedable to progressive system later in life and for the money you can not go wrong.
Ricky
Ricky, your killing me. Need new switch, yes!
Not to disscount other input, the way I check a fpss is just jump it post to post with wire (same as removing) then try it. Depending on switch sometimes they are not set correctly from factory. A lot of guys don't use one because of erratic operation, I do and reccomend one.
6 Second Club Moderator
