To those that purge through ram air nostrils, in here!
Old 04-24-2005, 03:51 PM
freakynipples69's Avatar
Default To those that purge through ram air nostrils, in here!
I was fooling around, getting ready to install my nos 5177 kit and I want to purge out of the top nostrils of the ws6 hood. How do you all run the tubing there? I figured best way would be to snake the rubber tubing around the hood struts and up along the hood and tape the tubing to the hood. It just seems very ghetto to me and if there is a better, cleaner way then this, please tell me! Post pictures of your setup if you could. Thanks in advance
Old 04-24-2005, 07:08 PM
01 Red WS6's Avatar
I want to see pics too. I want to purge mine through the hood when I get it set up
Old 04-24-2005, 10:59 PM
Green Thunder's Avatar
I used i piece steel lines on the hood that extend to of the hood and I have steel braided lines that go to my purge valves.. Just braised fittings to stainless lines... You can use steel brake line also.. I will take pics in the am and post them.
Old 04-25-2005, 08:29 AM
Smoker_98's Avatar
Thats what I did too. The purge comes out under the nostrils in the hood but it still works out pretty good. I'll snap you a pick.
Old 04-25-2005, 08:37 AM
I was thinking of doing under the nostrils but doesnt look as good as coming from the nostrils IMO. When I have everything done and setup the way I am going to do it, I'll post pictures and videos.
Old 04-25-2005, 10:47 AM
Ravenous T\A's Avatar
i'll be doing the same purge mod this week with dynotune dual purge kit.
Old 04-25-2005, 11:10 AM
haha me to, went with the master blaster purge kit. I am just waiting for everything to come in the mail. Post pictures of your setup when you are done, and a video would be awesome
Old 04-25-2005, 11:36 AM
I'll try and make a video, getting it tuned for spray this weekend, hopefully it won't be one of those "Nitrous on Dyno goes wrong" vids
Old 04-25-2005, 12:34 PM
Here are some pics of how I did mine..
Save the "Fast and Furious" & Ricer comments Please!
Old 04-25-2005, 12:55 PM
thats pretty much how I planned on doing mine.
Old 04-25-2005, 01:00 PM
BTW: I know the lights are ricey but I friggin love em! At night if you have an idiot in front of you and you dont mind taking a chance on the "impersonating an officer" hit the lights (without purging) and everyone gets the hell out of your way! They are VERY VERY bright!
Old 04-25-2005, 01:18 PM
I was thinking of doing the lights but too ricey for a trans am IMO, but they do look good
Old 04-25-2005, 03:30 PM
Bad30th's Avatar
My setup purges out the lower part of the WS6 hood but it's the same effect :
Cheers,
Bad30th
Old 04-25-2005, 08:22 PM
Cheers,
Bad30th
Great Idea! And probably a lot easier to install!
Old 04-25-2005, 08:58 PM
mrr23's Avatar
here's mine. i don't have the ram air hood. so, of course, i went through the two standard holes. the steel lines have since been replaced by brass lines.
Old 04-25-2005, 11:01 PM
98TXFBODY's Avatar
Location: Used to live in South Texas, Now in North Carolina
I have a camaro with the suncoast ultra z hood. I don't have a camera so I will try to explain how I did it.
In each nostril I drilled a small hole in the water baffle which is about 3 inches behind the mesh. I pop rivited the noid to the hood on the lower side that contacts the airbox when closed. I made a little braket the holds the noid on one end and has the rivit on the other with some sheet metal. the noid has a T coming out of it with brakeline running to both nostirls though the holes in the water baffle one into the mesh. The brake line is strong enough so it won't bend by the air hitting it.
I put the line and the and the wires in some wire loom and snaked a line though the hood and out a hole I drilled by the driver side strut. the line comes out right next to the stut and runs behind it down the driver side right next the the top of the fender to my main feed line. The only part that you have to really pay attention to is the amount of slack in the line. sit there and close the hood and peak at the line and make sure it doesn't snag on anything when it closes.
I have had this set up for about 3 years now with no problems.
Old 04-25-2005, 11:55 PM
Dude need to get a camera, I would really like to see of pic of this set up..
Old 04-26-2005, 06:43 AM
Everyone seems to be using copper tubbing for their purge lines. Is there any beneifit from using copper tubbing over plastic tubbing?
Old 04-26-2005, 02:05 PM
10 Second Club + 14 Second Truck Club
antz01ta's Avatar
mine is the same as Bad30th, works well and looks pretty cool
Old 08-19-2017, 09:04 AM
LS7Bird's Avatar
Would be great to revive this thread with new pictures on routing and types of materials used to run it out the nostrils... I'm looking to do this as well but have only found this thread.
Anyone?
Quick Reply: To those that purge through ram air nostrils, in here!
