How much rwhp through 36lb injectors?
Just curious how much rwhp a 36lb injector can handle. I have a 422 that should be putting down around 500hp and I'd like to throw a 75 or 100 dry shot on top of it but want to make sure my injectors are up to the task.
You'll need at least 48lb/hr.
Originally Posted by foxspy
Those injectors are too small. I'm running 40lb/hr and I put down 477rwhp and the duty cycle was up to 92%.
At your projected 600hp you'll need a min 46.9 injector at 80% duty cycle. If your interested in the math I'll give the equation and process to figure any HP=injector at 80%. Foxspy was correct, you can use smaller but you'll be static and that wears out injectors more quickly.
