whats a safe dry shot to run with a procharger p1-sc 6psi blower.
I have a 2000 Camaro SS with a 5177 dry kit. I have a walbro intank 255lph, and an inline A1000 pump, granatelli MAF. my valve train is stock, so is my bottom end. I also have SLP LT's with a borla cat back and a moser 12 bolt with 3.73's. i see 58psi of fuel, and 61psi when the A1000 turns on (which is at 2k rpms). I also have 42# injectors. On my blower im seeing 5-6 psi at 5k+. i had my car tuned and my AFR is 11.8 or below. I am shooting the nitrous into the ATI polished Air box. what do you think is the biggest shot i can run safely. i just put a .014 jet to cool the IAT's a bit.
i think it would gain more because of the compression. So 50 would be 100 or something. So I'd do something small like you did and go from there. Definitly should wideband it though.
