electrical gurus, i need your advice
Heres the problem, i have an MSD RPM activated switch that i use to turn on my inline fuel pump, and i also have an MSD Window switch which i want to wire to my nitrous set up. The rpm activated switch is already wired to an rpm source and 12v. is it safe to tap into both of these sources? or would i risk blowing a fuse some where?
i have 2 pumps. Walbro intank and inline aeromotive, which is like a fuel pump booster. the switch turns it on at 2k rpms. other options would be to turn it on when there is boost, but its pretty much the same.
