Bottle mount places???
I have removed my back seats a while back, but my question is, if i wanted to mount my bottle on that middle hump in between both seats how would i go threw with it, i have 2 bottle that look just like the pic below.
http://www.dynotunenitrous.com/store...p?idproduct=98
The only thing that i dont want to do is when i drill the holes is put the 4 nuts right above the drive shaft, by the way is that is hard as i put it cause i have seen pics of this before and love the look of it!!!
ps send pics if you can
josh
josh
If you dont want the bolts/nuts by the driveshaft then you could just weld it there.Or simply face the bolts up thru the wheelwell , the heads on the bolts aren't very big and won't interfear with the driveshaft. You might need some help from a friend to do it that way.
Thanx for the help smokeum99ta i thought about just facing the bolts thru the wheel well my self but had to make sure that it would look ok.
thanx
josh
thanx
josh
