best nitrious kit for my LT1
ok so im going to be gettitng a entire nitrious kit for my car soon and im wodering what kit i should be loking into/....i am going to be going wet and no spraying over a 125 shot.....any input would be good...thanks
Take a look at our kit:
http://www.harrisspeedworks.com/shop...cat=302&page=1
Each kit comes with a lifetime warranty that covers everything. If your not 100% satisfied with our kit we'll give you a refund.
Send us a PM or give us a call if you want to go over your set up in more detail.
Thanks,
Matt
Thanks,
Matt
Im going to have to say the best system on the market is Nitrous Express. The most common is there single nozzle kit.This system can produce up to 250hp.However it comes with the jetting for 35-150.
The next step up would be the maf kit.This kit has a TPS switch instead of a microswitch.The system consist of after market mass air ends with a spray discharge machined in the plate.It is also dual stage capable.The system can put out 250 hp on each side of the plate.However the system comes with jetting for 35-150.
Make sure you look at our dual nozzle kit special.It comes with a bellow but since you would not need it subtract 50.00 frome the 599.99 which makes this set up go for 549.99.
CLICK HERE https://ls1tech.com/forums/nitrous-oxide/320653-ls1-tech-dual-nozzle-special.html
Ofcourse all of NXs solenoids have always had a lifetime warrent.Pick a quality system that you can relay on time after time again.The good thing about running a name brand system is that if you need help in the future they will still be around.
Let me know if I can help you with anything.If you call in the prices over the phone are alot of times cheaper than they are on our website.
Dave
Dave
