Question about NOS kit
Do you mean what RPM band should you spray in? I don't quite understand the question.
Matt
Matt
Originally Posted by Kens98TransAm
Yup i have the WOT switch.....im just wondering how long should i spray for???
From reading your post it seems that you are doing highway runs.
It really comes down to the solenoid.NX says not to spray longer than 15 to 20 seconds with there 093 nitrous solenoid.Of course keep in mind that you also do not want to over spin the motor.
Now if you are talking about a quarter mile run its ok to spray it all the way down the track.unless you run slower than 20s.
If you are talking about RPM band.Keep it above 3,000 rpm and shut it off where you shift at but before rev limiter.
Dave
Dave
Yes im talking along the lines of Nitro Dave.....This will be my first time using it...it is for 1/4 mile racing....i have the WOT switch....the car is an a4.....im just wondering and would like to know when should i spray...(example rpm range, what gear, etc...) THANK YOU for any info and advice
