Anyone running FAST 90mm, 85mm MAF, TNT power ring??
Old 07-01-2005, 07:27 PM
theblur98ss's Avatar
Default Anyone running FAST 90mm, 85mm MAF, TNT power ring??
I can't get my system to fit right. I have an 85mm maf, 90mm TNT power ring and 90MM FAST setup. With no coupler the MAF is almost touching the power ring but the maf is about a 1/2" higher then the power ring. Is anyone running this setup. Did you have to do anything to get it to fit? I didn't trim my lid any but I think that would just make the alignment worse. Thanks a bunch for any help.
Old 07-02-2005, 10:07 AM
KCS
Moderator
KCS's Avatar
I don't have the same setup, but I had a similar issue when I installed my TNT kit. I just trimmed my lid at an angle to get it even with the ring, and then put a fernco in between the ring and the MAF. It takes alot of cutting and trimming to get the fernco right but it works and only took like an hour.
Old 07-02-2005, 11:27 AM
Beast96Z's Avatar
I have the same set-up. Your just gunna have to make it fit. It's obviously not a direct bolt on.
Old 07-02-2005, 01:26 PM
383ss's Avatar
I have near the same setup, just had to do trimming...
Old 07-02-2005, 02:28 PM
Ahhh never thought of trimming the lid on an angle. Boy I feel dumb now. Thanks guys.
