NX wiring. Need some help.
Old 07-01-2005, 08:43 PM
smokeum99ta's Avatar
Default NX wiring. Need some help.
I have a NX efi kit,heater,purge and opener. I'm moved my bottle location and my switches. I have a wiring diagram for each of the parts listed above. What I need to know is where do go on the relay. Every diagram I have from NX web site but it doesn't show where they go on the relay.Does anyone have a diagram of where the wires go on the relay???
Old 07-01-2005, 09:40 PM
Closed ex-Sponsor Account
NXRICKY's Avatar
terminals 85 white or ground for relay coil
86 red activation or 12 volt to relay coil, switch
87 green or main power output, to accessories
30 black is main power input to battery
hope this helps.
Ricky.
Old 07-02-2005, 12:34 AM
code4's Avatar
http://www.nitrousexpress.com/Pages/FPSS_diagram.htm
Old 07-02-2005, 02:03 PM
hope this helps.
Ricky.
I'm assuming that this will work for the system activation and heater right ? The opener has a relay built in the switch itself and the purge doesn't need one.
Old 07-02-2005, 03:26 PM
nosfedgta's Avatar
hope this helps
