Which progressive controller?
Old 07-05-2005, 09:54 AM
foxspy's Avatar
Default Which progressive controller?
Hey guys,
I was looking at the NX "2 dial" progressive controller for my nitrous system, but after some tests, I guess it won't work w/ the larger solenoids.
So, what are my options? I have a NX single spray bar plate kit, efi fuel pressure, and my FAST ecu is controlling the ground side of the relay.
I was looking at the NX/FJO dual window switch and getting the driver for progressive control but I don't need all that stuff. I don't need the TPS control and window switch since my FAST already does that. After looking at the FJO instructions, it looks like you can change the ramp time from 0 to 100%, but can not adjust the starting percentage, which is important.
Old 07-05-2005, 09:51 PM
foxspy's Avatar
Anyone?
Old 07-06-2005, 05:05 AM
foxspy's Avatar
Would this work?
http://shop.store.yahoo.com/hm-perfo...edprnico1.html
Edelbrock says that each solenoid can be up to 45 amps, where the N*S controller can only handle 10-15amps for the solenoids.
Old 07-06-2005, 07:25 AM
koolrayz's Avatar
I went with the Mazimizer. It had features that are redundent for me but the adjustable ramping, RPM based control, and different ramp programs for each gear makes it the only way to go IMHO
