window switch?
window switch?
i am about to put 100 shot on my car and wanted to get a window switch. does anybody have the msd digital one? is it any good? can it be used on lt1s? does anybody have the bmn window switch? does that need those little pills? which is better? thanks!
Either window switch is nice. I prefer the BMN, as it has the first gear lock out option. The BMN does not need the pills. We have a few instock.
http://www.harrisspeedworks.com/shop...age=1&featured
Thanks,
Matt
Thanks,
Matt
I ordered a BMN from Disco Dave,,I mean Nitro Dave
I was going with the MSD Digital, but needed the 1st gear lock out for my big Stall Converter.
bMN is a good one. If you don't need a 1st gear lockout, get whatever you like better
Originally Posted by TN94Z
I was gonna go with the BMN but decided I didn't want the 1st gear lockout...so I ended up with the Harlan and it has worked perfectly so far. It was really cheap too
Originally Posted by Jimmy P
Do you need to use pills with the new digital MSD one? Who has some good pricing on those, a NX 3 way switch, and a relay?
How easy is it to wire up the 1st lockout position? I have a t-400 trans.
The MSD digital is nice how ever good luck finding it in stock somewhere.MSD has not been able to completely fill anyones orders on these since they came out.WE get a batch in and they go right back out.WE even call other companys and buy what ever they have in stock.
Our best selling window switch is the BMN Controller.It uses turn dials and not pills.It has a optional first gear lock out which is great for traction issues on the street.It also has a shift light out put.The BMN sells for 129.00 and the MSD sells for 95.00.
Let me know if I can help you in any way.
Thanks
Dave
Thanks
Dave
The way i understand it the first gear lockout works by not activating the Nitrous system until after you've reached the upper rpm limit that you set on the window switch. So, if you go WOT in first and shift into second after your rpm's exceed the window switch’s upper rpm limit, the nitrous will then turn on through the rest of the gears.
So yea it should work for an auto-
