Melting #7 and #8 plugs on 250 shot single Fogger SHO ?'s
Old 07-20-2005, 09:37 AM
Nostang's Avatar
Default Melting #7 and #8 plugs on 250 shot single Fogger SHO ?'s
I ran my car last 2 wed nights at my local track on the 150, 200 and 250 hit to try to get some new bests despite the nasty heat and humidity. Just a little info on my setup. I have a dedicated fuel system with C16 race gas in it and I was running 7 gallons of C10 unleaded in the main tank (200 and 250 shots) (150 shot pump gas). I am running a 355 LT1 with ported heads/intake and all of the bolt ons. I have been running the car for the last 2 years on the bottle with this setup on the 150 hit and I decided to start spraying the 200 hit to get into the single digits.
Well the heat and humidity sucked at Cecil but I was able to manage a new best. I was on the 200 shot and I had some C10 in the tank and pulled 4 degrees of timing. The A/F ratio was 10-1 the whole way down so I have a little bit of leaning out to do with the car. The timeslip read
1.463
4.177
6.495
105.87
8.503
10.203
132.63
All in all I was pretty happy. The car dead hooked but because I am running so rich it did not leave as hard as it should have on a 200 hit. Any ideas on why it isn't hitting hard?
I tried the 250 shot on the next pass but I am having problems melting #7 and #8 plugs in mine on the 250 shot. I tried the 250 hit that night but the car felt sluggish off the the line and surged a little in the top of second about 500ft out so I let out and hit the brakes and went a 11.1@90mph with a 1.53 60 ft....lol. The car felt slow off the line but it was actually faster from 60-330 and 330 to 660 (6.506@103mph 1/8th letting out) by a tenth. I am clueless as to why it only melted 7 and 8 (wasn't totally melted because I let out ASAP) I was pulling 7 degrees on the 250 hit.
I also ran the car last week in less than optimal weather on the 150 hit and pump gas with the M/T drag radials. The car was at 10.3-1 the whole way down and I was pulling 6 degrees of timing. Again the car dead hooked but did not leave as hard as it should have. The timeslip read:
1.546
4.358
6.749
102.56
8.818
10.570
128.70
My best ET ever was a 10.354@129 with a 1.437 60ft on the 150.
Any ideas on why I still melted #7 and #8 plugs on the 250 shot even though I was running 10-1 a/F ratio? All of the other plugs looked fine. I am thinking I am having a distribution problem but I am not sure. Any suggestions on how to fix it?
Thanks in advance,
Matt
Old 07-20-2005, 09:48 AM
11 & 7 Second Clubs
Race Car Driver's Avatar
Those two cylinders tend to run leaner than the others, but your situation seems extreme.
Old 07-20-2005, 09:56 AM
8 second mod
Noyzee's Avatar
sounds like those cylenders need more fuel. maybe a single nozzle isnt good for your setup
Old 07-20-2005, 11:38 AM
LS1TECH Sponsor
DynotuneN2O's Avatar
I agree with Brad, typically a fuel issue/distribution.
Old 07-20-2005, 11:50 AM
8 second mod
Noyzee's Avatar
Dean, he may need you to price him out a DP system!!
Old 07-20-2005, 11:57 AM
NXJeremy's Avatar
On 250hp and higher I would suggest going to a direct port on the LT1 motor. I've seen the same problem on some other LT1's, although I agree with BickelFirebird that your situation does seem a little on the extreme end of things. About the issue of the car not leaving as hard as it should, 10:1 is too rich IMO. That's why the car leaves lazily, we usually tune cars to be about 12:1. However, the #7 & #8 plug issue would need to be taken care of before leaning it out to 12:1.
Old 07-20-2005, 04:51 PM
SDB
SDB's Avatar
what intake are you runing?
where is nozzle at?
lean out fuel jet a little to get AF ratio 11.5-1
May have too much timing taken out for 250 shot (7 degrees is a lot, especially with sch good gas)
SDB
Old 07-20-2005, 05:10 PM
NXJeremy's Avatar
SDB- I am curious about your thought/reasoning for suggesting him to lean the motor out and add timing when he is already melting plugs.
Old 07-20-2005, 05:32 PM
NXJeremy's Avatar
Nosstang- Nitro Dave had the same problem with #7, and he was even running a direct port. He said his problem was entirely the nitrous system though. I've talked to several people and most say it is the intake design, and a direct port should solve the problem. Nitro Dave also said he could install spray bars in the intake, which should solve the problem. Otherwise, I would suggest backing it down to 200hp and leaning it out to 11.8-12:1 and let it rip.
Old 07-20-2005, 05:35 PM
Nitro Dave's Nitrous Outlet's Avatar
I have seen this problem before.
For some reason the LT1 intake desighn is poor and those two runners run lean.It looks like you are at the point of needing a directport.If you were good at the 200 back the system back down and get the air fuel to about 11.8 to 12.1.This will take the bog out from being to rich.If I can help in any way let me know.Sorry I seen this post so late.
Dave
Old 07-20-2005, 07:36 PM
white2001s10's Avatar
Dave
The intake was not designed for wet flow. This is why you run into problems with the wet systems.
The plugs melt due to a lean condition in those cylinders. You have a few options. I'd also get some stouter plugs in there too. A plug failure can take out your entire engine. I'd suggest trying one of these autolite plugs... whichever one fits into your heads: AR51, AR12, AR472
As a quick fix, try running at a lower engine coolant temp next time. The chambers won't overheat as quick and you'll get more fuel delivered via the injectors.
Old 07-20-2005, 11:57 PM
SDB
SDB's Avatar
I meant on the 150 kit...try getting it better with AF ratio, and double check to make sure your not taking out too much timing....not meaning to put a smaller fuel jet in on a 250 shot right off the bat! I have never burned out plugs but have hurt them with too much fuel.
Like another said, try better plugs, maybe one step colder. Probably just the limit of the LT1/LT4 intake design, 150 is ok, 200 is marginal, 250 is aparently too much.
SDB
Old 07-21-2005, 05:51 AM
Nostang's Avatar
Thanks for the replies and suggestions. I will stick to a 200 and under shot until I am able to get a direct port. I am almost scared to try and lean it out to 12-1 though as the whole bank could be at 9.6, 10.3, 8.0, and 14-1 A/R but still read rich on my wideband if you know what I mean.
BTW, I was running AC delco R42LTS plugs and my engine temp was ~160-170....it never goes above 170. I am going to try some autolite 103's to see how they work next time at the track. I also bought a sprak plug reading kit so I should be able to analyze my plugs better. Ultimately, a direct port would be a wise investment.
Thanks again!
Matt
Old 07-21-2005, 10:40 AM
NXJeremy's Avatar
SDB- I gotcha, sorry about that. I get confused sometimes when I read these posts, lol.
White2001s10- No intake was designed for "wet flow".
Old 07-21-2005, 12:54 PM
slow trap's Avatar
what would be wrong with keeping it at 150 wet and hitting it with a 100 dry shot if injectors is up to the task?
Old 07-21-2005, 01:11 PM
NXJeremy's Avatar
It would be nice to have a FJO engine management system. That way you could tune the car sequintially and fatten up the two cylinders you're having problems with.
That wasn't a question, but you are incorrect just the same.
Several manifolds incorporated many hours of research to reduce fuel distribution problems in wet-flow systems.
None of the dry-flow intake designs today would fly by even 70's standards for use as wet-flow.
Old 07-21-2005, 01:22 PM
V8_DSM_V8again's Avatar
I would consider converting the fuel rail to a parallel feed and using a hq hv pump and regulator.
You could be starving those two injectors.
Old 07-21-2005, 01:33 PM
NXJeremy's Avatar
Exactly what production EFI intake was designed to have fuel flowing through it?
I think one of the nitrous companies on the market needs to hire you as soon as possible, you seem to be the be-all, end-all of nitrous knowledge, haha. I guess to each their own.
Old 07-21-2005, 01:35 PM
NXJeremy's Avatar
Kinda off topic, but.....V8_DSM_V8, saw your sig and I would definately say put the LS1 in the RX7. It is a beautiful car and looks even better with an LS1 in them, haha
Quick Reply: Melting #7 and #8 plugs on 250 shot single Fogger SHO ?'s
