Tach line
You need to splice the tach signal at the PCM. If your car is a '98, it will be on the BLUE Connector, white wire, PIN#35. If it's a '99-02, it'll be on the RED connector, white wire, PIN#10.
Hourang.. I was in the middle of doing it.. So I just needed to know the wire # as soon as possible.. And I completed it.. Up and running. needs a few other tweeks, but it's goin.. so this one's for you buddy.
And thanks GM muscle..
