Jimmy jam micro switch???
Old 08-03-2005, 07:21 PM
fastsspr's Avatar
Question Jimmy jam micro switch???
Ok i already finished the instal of my NX MAF sistem.But the micho switch has
3 pins for wires.Some body can explain me how can i hook it up?In the NX instruction it only have 2 pins,one goes to the relay and the other one to the swith.I did that it not activate the selenoids.Were i have to put the 3er wire to make it works?
Thanks in advance!!!
Old 08-03-2005, 09:26 PM
02Z28's Avatar
You don't use the top terminal on the micro switch, the middle terminal on the micro switch goes to the middle terminal on the arming switch, and the bottom terminal on the micro switch wires to #86 terminal on the relay.
