Car tuned lean N/A.. Need help with jetting???
My car sits at 12.9 - 13.2 A/F ratio....N/A. I want to run a 100 shot wet..
I was told the jetting for my NX kit is 52 / 28. I do not want to run lean..
Can i richen up the fuel jet say 52 / 31>>> Will this work or is there something else?? Please help... ????
More then likely you will be running richer with the standard jets. Most of the NX systems do.
BUT, with that said, you should really run it on the WB just to make sure. Better safe then sorry, but I personally believe you will be safe with the recommended NX jetting from the cars I have seen.
