nitrous A4 problem
nitrous A4 problem
ok i have a problem i have a NX wet kit 75shot when i spray and its about to shift it hits the rev limiter i was doing it on the stock tranny and i ended up messing it up then i got a rossler stage 3 tranny and a 2800 stall and it continues to do the same whats the problem? how and i did have a msd window switch but couldnt ever get it to work
get the window switch to work, but a A4 doesnt really need one, more of a safety thing for m6, unless ur spraying a big shot. when u know or feel its gonna shift, get out of WOT until it shifts, so that extra 100tq or so doesnt shock the trans.
My tranny use to do that as well. It will bang the limiter on the 2nd to 3rd shifts but not 1 to 2nd while spraying ot shifts. I bought a msd digital window switch and it stoped.
You are not leaving the bottle heater on when you are making your pass are you? Also do not pull your e-brake up to turn off the running lamps that could also affect the shifting. I know it seems wierd but the first one actually turned out to be the problem on a buddy's car.
