Nitrous for a dummy
Nitrous for a dummy
I am thinking about adding a system to the car, but I do not know much about it.
What is the safest system to run 100 shot, do I need a rpm window switch for a 6spd car?
what are the advantages to wet or dry?
any help is appreciated.
Most of the systems out there are safe, as long as you use the proper safety equipment (Fuel Pressure Safety Switch, window switch (yes, get one), set of colder plugs (NGK TR-6). Look into a bottle heater too. How big of a shot do you want to run? Depending on how big of a shot you are going to run you might need larger injectors if you go with a dry kit.
Thanks,
Matt
Thanks,
Matt
