nitrous newb
Old 08-19-2005, 11:11 AM
2000WS6TA's Avatar
Default nitrous newb
if i want a nitrous kit would it work well on my stock t/a or will i need to do some modifications to get it working good i dont want any thing huge maybe like a 75shot or somthing please help me with what ill need
Old 08-19-2005, 11:20 AM
00 N20Bird's Avatar
It would work, many people have done it. I would just recommend some safety applications - a WOT switch, a window switch, maybe a fuel pressure safety switch.
Old 08-19-2005, 11:23 AM
dscott's Avatar
No need for any modification when installing N20 (except switch panels or gauge installs). Any kit thats not direct port is a pretty simple bolt-on.
But IMHO, I wouldnt run any shot without getting a dyno tune by someone that is familiure with late model engines on N20. You should take out some timing.
Old 08-19-2005, 02:54 PM
Matt@HSW's Avatar
You'll be okay with a 75 shot. Change out your spark plugs to a set of NGK TR-6s and pick up a window switch & fuel pressure safety switch when you get your kit and you'll be all set. If you decide to move up to a larger shot down the road you might want to look into a larger fuel pump and a PCM tune. Take a look at the kits on our website.
http://www.harrisspeedworks.com/shop...cat=302&page=1
Let us know if you have any other questions.
Thanks,
Matt
