Did search, no luck
Did search, no luck
I'm going to be installing the nitrous soon. I have seen MANY install guides with basic graphics, are there any guides out there specific for the LS1? Just curious. Would save a few headaches. Like I said, I have done many searches and have only found the manufacturer's instructions. If their aren't any, I know wehere to look for the basic ones. Thanks guys!
-Mike
-Mike
What part are you needing to be LS1 specific? Run the wires as clean as possible. Use white #10 tach tire for window switch. Use the guides that come with your parts and piece everything together. Make your own brackets or use the supplied ones in kit. Read the directions over before you begin. Make sure you understand everything. Grab a soddering iron, some electrical tape, and get to work!
