Need Some Wiring Help With Remote Bottle Opener
I just received my remote bottle opener from Dynotune, but I have a problem. It came with a switch that I'm supposed to attach the four wires to, but I can't use this switch as I'm using the NX console switch assembly instead. The problem is that I now have two wires coming off the remote bottle opener motor (one red and one black) and four wires to hook up to them (two wires from the remote bottle opener switch in the NX console and two wires (positive and negative) coming from the battery.
How can I wire this thing up now?
Thanks!
Thanks!
Closed ex-Sponsor Account
Thanks!
Thanks!
http://www.nitrousexpress.com/Instru...witchpanel.pdf
Ricky
which opener did you buy from Dynotune. They sell 2 and get wired differently.
If its the " turn the actual valve style" then wire it per NX's instuctions
If its a solenoid style, then it not compatable with the console switches
Ok, I just got to thinking..................
I'm connecting the opener to an existing, pre-wired system. The NX console switch assembly is already successfully arming the system and operating the purge solenoid, so it already is switched hot and grounded. So all I have left to do is connect the two wires from the opener to the opener switch in the console, correct?
Some bottle valves require alot of force to seal completely. Be sure to check for leaks by brushing on a soapy water solution at nipple exit and by dipping bottle in bathtub before in installing. In my area nitrous is $3.00 lb.
