can I spray a 100 or 125 shot on stock timing
Originally Posted by 70Stang
Yes. All day, every day.
Moderator
Stock timing (on my year) was at least 6 degrees
short and stock fueling was way over-rich. Under
these conditions, you could probably get away
with it. But if you have leaned out the fueling some
of that cushion may have gone away. You might
want to clean the MAF just for luck as you indicate
a K&N filter. Over time that will drift the MAF output
and make for both leaner mixture and higher advance.
