Want to purge only when system is armed - NX switch panel gurus step inside
Old 09-04-2005, 10:44 AM
Warp6's Avatar
Default Want to purge only when system is armed - NX switch panel gurus step inside
I have a C5 with the NX switch panel mounted in the ashtray. The only problem with it is if the lid closes too far it will push the purge button. I want to make the purge work only when the system is armed. How do I wire it? Thanks in advance, Craig
Old 09-04-2005, 12:34 PM
BonerBen's Avatar
Tap the power wire of the purge noid to the arming switch.
Old 09-04-2005, 02:21 PM
Warp6's Avatar
Sorry, I don't get it. Are you saying take the power off the purge switch and run it to the arm switch? Which pole do I connect it to? Fron the NX diagram for the switch panel I would connect #3 of the purge switch and connect to #3 on the arm switch.
Old 09-04-2005, 02:52 PM
Bad30th's Avatar
Run the +12v for the purge switch from the switched wire on the 'arming' switch (instead of running 12v to the purge, run its power from the arming switch's on/off wire).
Make sense ?
Bad30th
Old 09-04-2005, 09:50 PM
2001 Red Coupe Bandit's Avatar
I have a 2001 Vette and am doing the same thing, NX Switch Panel. I hope I don'r run into the same thing...
I wonder if there is a way to make the door not hit?
Old 09-05-2005, 10:08 AM
Airwolf's Avatar
I have not seen this on my C5, but I added an arm switch to my setup for peace of mind on the bottle heater. Call me paranoid, but I wanted that extra "step" to keep everything off when I was not using it.
My purge switch is "on" when I push the top of the switch. I know my cover is not even close there, but the bottom area of the switch could be press if the "on" was there instead.
Old 09-05-2005, 05:04 PM
brad8266's Avatar
Go to NX websit and check out their schematics on wiring, they worked great for me. As to your question, like said already, tap +12V from the arming switch.
Old 09-06-2005, 10:47 AM
Closed ex-Sponsor Account
NXRICKY's Avatar
Did you get it working.. If not let me know I will send you a drawing.
Ricky
Old 09-06-2005, 04:33 PM
NXRICKY's Avatar
Take a look at this.. Notice the hot wire connecting the purge switch to the arming switch
Ricky
Old 09-08-2005, 01:58 PM
Warp6's Avatar
Ricky, worked like a champ! Thanks, Craig
Old 09-08-2005, 02:36 PM
NXRICKY's Avatar
Your welcome.
Ricky
