Who Runs an NX TPS Switch Right Now?
Old 09-04-2005, 05:08 PM
2001 Red Coupe Bandit's Avatar
Default Who Runs an NX TPS Switch Right Now?
Just curious. I am installing mine next week and have a WOT Switch that came with my NX Kit and also got the TPS from ND because my installer said it was easier to install.
All I see is posts that say no one can get them to work correctly, so I want to see who is actually running these and if they have been working consitently for an extended period of time.
I have a C5 Vette, but I am sure they are similar for all LS1's...
Latest Example X-Troopercouldn't get his to work and went with a WOT switch, AirWolf had troubles with hius and went with a WOT switch. Now mine is the latest one so maybe the bugs are fixed?
Again, whoi is running there and reccomends them.
Thanks
Gary
Old 09-04-2005, 05:11 PM
BonerBen's Avatar
I have the nx tps switch on my 02 Z06 and have had 0 problems so far.
Old 09-04-2005, 09:49 PM
Cool My friend. Looks like I will be OK. Our other friend with a Vette X-Trooper for some reason didn't get his working, but I am not sure WHY?
Maybe installer error, maybe a defective piece, or maybe you have to know a few tricks
Old 09-05-2005, 08:22 PM
99SLOWC5's Avatar
I just finished my install this weekend, with the NX TPS switch, I'll post my stealth install pictures later in the week. The swtich works great
JEFF
Old 09-05-2005, 08:57 PM
Cool we have similar cars. My best times pre nitorus are in the sigs and the gas should help us into the 10's
Old 09-05-2005, 09:00 PM
99SLOWC5's Avatar
yeah I'm hoping with the tuning to help out my stall shutter I had, 28" tall slicks and the 150 shot. I'll get close to 10.50's
Before some tuning recently done. The converter would shutter once stalled up to 2500rpm's. Thats fixed and I can no stall up to 4000R's without a problem so looking for those 10.50's, cage should be here soon I hope
JEFF
Old 09-06-2005, 07:15 PM
Are you spraying throught 1st gear????????????????
What are you setting your window switch to for your ON and OFF Parameters?
Thanks
Gary
Old 09-06-2005, 07:17 PM
99SLOWC5's Avatar
the plan is to spray out of the hole as soon as I'm at WOT, and after hopefully 10.50 seconds let off No window/rpm switch, spraying through the shifts
JEFF
Old 09-06-2005, 09:53 PM
99SLOWC5's Avatar
heres some pictures of the install
Attached Thumbnails Who Runs an NX TPS Switch Right Now?-p1010001_internet.jpg   Who Runs an NX TPS Switch Right Now?-p1010002_internet.jpg   Who Runs an NX TPS Switch Right Now?-p1010007_internet.jpg   Who Runs an NX TPS Switch Right Now?-p1010005_internet.jpg   Who Runs an NX TPS Switch Right Now?-p1010006_internet.jpg
Old 09-06-2005, 10:24 PM
99SLOWC5's Avatar
Gary are the wires on your switch,
pink, red, white and black
or
BROWN, red, white and black?
Mine was pink, the NX book i received said brown. I dont know if thats anything to tell the age of the switch or not. But something to think about
JEFF
Old 09-06-2005, 10:52 PM
Looking right now,,,
Pink, Red, White, Black and I have the pretty little NX circular sticker on the unit as well
Ole1830's Avatar
I'm using one. I had a little trouble figuring out the install, but haven't had any issues since I installed it.
You might have to adjust the screw ALOT to get it to come on, btw. I had to open mine up about 15 turns to get the relay to fire.
Old 09-06-2005, 11:00 PM
99SLOWC5's Avatar
Gary,
I HAD a NX sticker on mine also, just making mine a little harder to find now by taking it off
JEFF
Old 09-07-2005, 08:44 PM
I'll be down the track so damn fast, no one will ever see my sticker, they will see my licence plate
OK, I will sit down Now
Being fast is boring, but someone has to do it.
Old 09-08-2005, 05:26 AM
XTrooper's Avatar
Gary,
Get that damn system installed! I want to see some times!
Old 09-09-2005, 05:34 PM
I am trying Trooper. This nitrous takes a long time to get everything working right it seems, always something that doesn't seem to go right
Old 09-10-2005, 11:01 AM
8 second mod
Noyzee's Avatar
i have 2 for sale, i put them in my car and another car we did, didnt care for them, but they would be cool an a "street" car
Old 09-10-2005, 11:11 AM
99SLOWC5's Avatar
are these issues coming from the start? As in the switch never worked? Or a prolonged issues that becomes a problem. Maybe the switch was exposed to close header heat or something? I've only had the Kit working for about a week and made 3 pulls with the juice and my install went smoothly and everythings worked great so far... Just wondering what all the problems are/were?
JEFF
Old 09-10-2005, 11:14 AM
8 second mod
Noyzee's Avatar
mine worked for a while, then it needed to be adjusted al the time, one time it kicked the spray on about 60 feet out, then shut down, and kicked back on, i almost hit the wall! that was the last of that.
im not a big fan. im sure they are nice, but just didnt work well for me, i like the old simple $5 WOT switch.
this is all personal preffrance.
Old 09-10-2005, 11:17 AM
99SLOWC5's Avatar
my switch was purchased back in may, when was yours purchased, wondering if they changed anything. I'd hate to have the same experience you incountered. As you can see in my pictures, I tried to keep the most stock looking stealth setup possible.
Thanks for the fast replies
JEFF SMITH
