soleniod question
Old 09-07-2005, 10:47 AM
zerotosixzero's Avatar
Default soleniod question
can i use a leftover fuel solenoid to build a purge kit, its left over from a plate system on a carb motor
Old 09-07-2005, 10:59 AM
Ping King's Avatar
yea definately
Old 09-07-2005, 11:00 AM
perfect. thanks for the speedy reply
Old 09-07-2005, 11:21 AM
Airwolf's Avatar
Are you sure on this? Most nitrous solenoids are rated for the 1100+psi, not sure the fuel solenoids are rated the same psi. I think one of the vendors should answer this to be safe.
Old 09-07-2005, 11:51 AM
Nitro Dave's Nitrous Outlet's Avatar
No you can not use a fuel solenoid as a purge kit........Airwolf is correct they are made completely different than a nitrous solenoid.
Dave
Old 09-07-2005, 12:21 PM
well then i need to purchase a purge kit then.
Old 09-07-2005, 02:13 PM
Ping King's Avatar
ohhhhhh i didnt look...i thought it was a nitrous solenoid...yea...you dont wanna do that hahah.
sorry about that...even though it said fuel solenoid. yea theyre different.
listen to dave hes the man.
Old 09-07-2005, 02:29 PM
Ping King's Avatar
yea...i guess this is an example of why you should wait for a few other people to answer...i didnt read the post all the way..and you coulda had a problem..or just wasted some time.
Old 09-08-2005, 04:27 PM
cantdrv65's Avatar
youll almost certainly blow some pieces of that fuel solenoid apart.... maybe through the hood or your body.
Old 09-09-2005, 11:03 AM
LS1TECH Sponsor
DynotuneN2O's Avatar
You can get the purge kit from any vendor here... our kit cost $69
www.dynotunenitrous.com
Cheers
Dan
