Who uses just a WOT switch? (no window switch)
I have a NX wet kit and just ordered Nitro Dave's microswitch. My question is, who uses a WOT switch only, with out anything like a window switch? Any problems? I figured I will run a WOT switch as well as a push button, and plan on spraying out of the hole. I know not to spray under 3000 rpms. Anything else? Thanks guys.
Just hope the throttle doesn't get stuck open like mine did, against the WOT mircroswitch. Good thing I had the MSD digital window. Plus it helps out, because you may not want to spray it out of the hole every time. So you can set it at a higher rpm to activate.
With a stall you really can run without one....You are going to be above 3000 Rpms regardless. There isnt the chance of missing a shift either. Is it safer to run with the switch? somewhat....
Restricted User
I know Dave really supports the safety stuff, and one day I may get a FPSS, but never ran any WS or FPSS and probably wont. Personal decision that I do not attempt to persued others into following.
I really dont need to run a window switch either since I will only be running nitrous in 4th and 5th to top end the car-but I put one in in case I ever get into a race with a fast car.Duh
8 second mod
i ran all types of fancy **** when i first put the setup in my car, and after everything screwed up, and the wiring nightmare ect ect, i run the least amount and the simple set up.
I ran just a wot switch with a 3800 stall. No problems with the motor, but the tranny couldn't take it. If something ever happened you could just turn off the activation arming switch.
