Why not direct port?
Old 09-11-2005, 09:04 AM
RealLiveMD's Avatar
Default Why not direct port?
From what I've read both wet and dry kits can malfunction leading to total engine loss. However, Direct port kits for only $600-700 more will be much safer on a stock car. If this is true, then I'm thinking $1200 for the kit, $600 for accessories, $400 install and I have a relatively safe daily street driver with an extra 125 shot. Shoot holes in this theory if I'm wrong.
Old 09-11-2005, 09:11 AM
Turo's Avatar
Well, the nice thing about them is that they get a beter mixture to the cylinders. They tend to be used for bigger shots though, most DP kits will tell you the smallest recommended shot is a 150 or so, so it depends on how much you are going to spray.
BTW, you may want to have a mod move this to the nitrous section, may get more opinions over there.
Old 09-11-2005, 04:15 PM
RealLiveMD's Avatar
From what I've read, a few people get by on a 150 shot, but the 125 seems to be the safest for the stock bottom.
Old 09-11-2005, 04:27 PM
Matt@HSW's Avatar
If done correctly a 150 shot is perfectly safe on a stock bottom end LS1. There are people doing 250+ shots successfully on stock bottom end cars.
Matt
Old 09-11-2005, 04:46 PM
badass 2002 z28's Avatar
A direct port isn't worth it unless u plan on spraying more than 150..bigger shots are where DP's really shine
Old 09-11-2005, 05:56 PM
ls1408cp's Avatar
if you just buy the good kit now you dont have to buy it in the future and it is better on the motor every cylinder sees the same amount of fuel and nitrous
Old 09-11-2005, 06:08 PM
Airwolf's Avatar
I am doing a 175 now. I really wanted the "look" of the Direct Port.
I had a single nozzle that worked great but looked like every other nitrous setup. The only real advantage of DP is the WOW factor for anything 200 or less; at those levels a single/dual nozzle will do. My friends who are not car guys even freaked when they saw the DP system, but hardly noticed my single nozzle system.
To use a DP on small shots (200 or less) you will probably have to go with a fuel regulator or stand alone fuel system that regulates to 10 PSI. Staying a high PSI with a small shot can (and has) caused problems from the jets being so small. At 60 PSI, for a 150 shot, the jets are .012 (super small) but a 10 PSI, the jets are .020, almost the same size as the nitrous jets at .024 . So be prepared for that added expense and fun of the install. Also be prepared for 1 hour to change jets! Luckily I am at the level I want now.
Good luck.
Old 09-12-2005, 10:42 AM
Nitro Dave's Nitrous Outlet's Avatar
A directport is a nice way to go.I do not suggest a direct port for anything over a 250 hp shot normally.The directport obviously cost more money but also requires more time and tunning.I would suggest a top quality system like a NX single nozle or maff system.With all the accessories you will have fuun time and time again just as safe.
Dave
Old 09-12-2005, 04:20 PM
chpmnsws6's Avatar
Dave
you don't like direct port systems if your shooting over a 250 shot?
Old 09-12-2005, 04:34 PM
Turo's Avatar
I think he meant that he recommends direct ports for 250+ shots.
Old 09-12-2005, 04:37 PM
Matt@HSW's Avatar
Agreed I'm just as confused as you, but I'm pretty sure it's a typo.
Matt
Old 09-12-2005, 04:46 PM
correct,
Sorry its a typo.I normally suggest Directports for 250 or above.There is nothing wrong with running it on smaller shots.Its just not as critical.
Dave
Old 09-13-2005, 03:09 PM
chpmnsws6's Avatar
okay, just making sure
Old 09-13-2005, 04:32 PM
Thanks
Old 09-13-2005, 08:20 PM
RealLiveMD's Avatar
The problem was i read one of the FAQ's which gave a lot of real world drawbacks for the other kits, plus rumors about bad spark plugs, etc. Being a newbie, it seemed simple, pay the extra g, and spray 125-150 shot without worries.
Old 09-13-2005, 08:44 PM
hashtagBMW
Speed Density's Avatar
DAVE, what do you recomend on a 383 storker? I plan on getting a rebuild and i want to spray it, looking for low 12's high 11's but very very streetable!
Old 09-13-2005, 10:03 PM
11SECDWS6's Avatar
This may sound like a silly question but do you need an O2 sensor for each cylinder if your running direct port?
Old 09-14-2005, 12:15 PM
chpmnsws6's Avatar
no, they all spray equaly among the rail
Old 09-14-2005, 12:27 PM
FastBlackTA's Avatar
A DP system might be overkill on a stock bottom end depending on how much you want to hit it with. Check my sig for DP pics if you're looking into how they can be done.
Old 09-14-2005, 12:32 PM
chpmnsws6's Avatar
i originally bought it to equalize the flow to all the cylinders, trying to help the bottom end last alil bit longer
