What will a 26lb inj and stock pump support
Old 09-14-2005, 02:24 PM
JS
JS's Avatar
Default What will a 26lb inj and stock pump support
Just curious as to what RW this setup will support
400RW/420RW etc......
Old 09-14-2005, 02:50 PM
8 second mod
Noyzee's Avatar
we did 430 and 400 with them, but the cycle was pretty high with a 100 shot on top
Old 09-14-2005, 02:57 PM
JS
JS's Avatar
Was that dry or wet...
I'd imagine dry....
Old 09-14-2005, 03:10 PM
8 second mod
Noyzee's Avatar
both. but the wet was better with a better intank pump. it made over 530 with a 100 shot.
Old 09-14-2005, 03:23 PM
99SSLS1's Avatar
mine did 418hp 463tq at 90% injector duty
Old 09-14-2005, 03:39 PM
JS
JS's Avatar
I'm already at 340RW
I wanted to run a 60RW dry shot to hit 400RW....
Old 09-14-2005, 06:34 PM
Restricted User
CAT3's Avatar
That stock injector will run all the rwhp you want off a wet kit. The pump will run more if you use a fuel pump hotwire kit. On dry, not nearly as much, since the injector would begin to limit you quickly.
Old 09-16-2005, 10:43 AM
JS
JS's Avatar
Anyone else?
Old 09-16-2005, 04:39 PM
VTC_WS6's Avatar
How much moreso would a set of 28lb injectors add in terms of capability? I'm guessing about another 40-60whp at most over 26lb injectors...?
