.022 fuel jet instead of nitrous jet
What sized jet was used on the N20 side?
Originally Posted by 99 Pewter TA
What would happen if you use a .022 fuel jet in place of a nitrous jet? How big of a shot would this be?
Fuel and nitrous jets are interchangeable, and a .022 is roughly a 35-40hp shot on an LS1...
http://www.nitrousexpress.com/Instru.../gmjetting.pdf
Bad30th
Bad30th
Bad30th
Bad30th
Bad30th
Bad30th
This was a dry kit on a 5.0 mustang. I am not sure what was on the fuel side. I went to nitrodave's website and saw the opening was really big on the fuel jet vs the NO2 jet [IMG][/IMG] [IMG][/IMG]
I don't know anything about nitrous, but the system did not have a fuel side. The nitrous was injected down the cold air intake down by the K&N air filter. Remember this was on a 89 mustang. There was only a nitrous side. I just thought opening looked alot bigger than a pen point. This hole looked like a ball point pen head. I guess the motor did not get enough fuel from the intake.
Originally Posted by red90cobra
the opening is not that big. it's there so it will mate with nozzle. the hole is the size of the tip of a .05 lead pencil well even smaller than that .022. you get what I'm saying?
Originally Posted by Robert56
Some may have drilled it out? Mustang kit, does it use an aux fuel pump to spike the injectors?
Robert
Robert
I found out Saturday night that the jet was drilled out. I don't that much about nitrous, but I knew something wasn't right about that jet. Thanks for all the help and replies.
