guys with tr 224/224 cams ! look !!!!!!!!
Hey guys what kind of power are u guys making with the spray and are yall using a dry or wet kit and i want to know from the guys that have this cam with a 112 lsa
We just finished up on 2 224 cam cars. The one car is spraying a 150 shot and he is putting down 583 rwhp 595 rwtq. The other 224 cam car is doing a dual stage set up, 1st stage is dry the other is wet. We just started tuning that car, but he should be in the 650 RWHP range.
Matt
Matt
Matt
Matt
this is a cam only car on pump gas that we are talking about, those are some sick #'s for a little 224/224 cam on just 150!
Matt
Matt
and thanks
It's a wet shot. The second car is doing the dual stage, one stage dry the other wet.
But back to the first car, he is on the board, maybe he'll chime in?
Cam only (stock heads) on pump gas using a LS1 Timing Tuner. It's actually an old MTI cam grind that came out of my car a few years back.
Matt
Matt
Originally Posted by red fury
what is the cars rwhp all motor? 150dry and you got those monster #'s
114 LSA. Wet kit in a M6 car.
Matt
Matt
was this on the 112 lsa and a dry kit or wet kit for the car that amde 583 rwhp and was it a a4 or m6
and thanks
and thanks
Sure, a 112 LSA will work equally as well on that size shot. You don't see a lot of gains when using a specific nitrous cam until you start doing some big shots.
Is your tranny built? If not get a window switch, along with a set of NGK TR-6 spark plugs, a fuel pressure safety switch, and a bottle heater since you are going with a wet kit. Let me know if you have any other questions.
Thanks,
Matt
Thanks,
Matt
would the 112 work good on a 100 shot wet matt and what all would i need for my car it a a4
398rwhp and 387rwtq.....no tricks, on 17x11's with 315's, no belts removed, and on a warm humid day....all motor, tuned with my Diablosport Predator....
I don't have any spray numbers, but on the 150 shot, I ran a 127mph in the 1/4 mile on the 315 drags...with a 2.0 60ft and race weight of 3760 lbs....
112 lsa........
112 lsa........
Originally Posted by tntws6
What was the ET for that run? The car must be making some power, but did it ever hook after the 60' mark?
The ET was 11.6 at 127 with a 2.0 60ft......as you can see, the mph is 10 second mph, but the 60ft sucked.....it's all about the 60ft at the track.
My car is only a street car, so watch out on the street! But I can easiley lose a race at the track to a slower car, just a better 60ft'er!
Once I was out of 1st, I started hooking alright on the 315 nittos....
What kit would you recommend...A wet or a dry? I am looking into this with a tr224/224 114 cam in this!!! www.ls1miata.net/gallery. I am the red one!!!
I am looking at 50 to start off with and work my way up. Call me crazy!! I am getting it tuned next week first to see what my numbers are and then use the spray for a litttle more fun!!! It most likely weighs in around 2600lbs.
As light as you are, you probably are crazy! If you do go with one I would recommend you go with the TNT kit. It's a good looking kit and one of the hardest hitting ones...
Better invest in slicks!
that my car that Matt brough up earlier in the thread...
car made 393rwhp and 385rwtq on the motor..no tricks..stock gears and rear.
583rwhp and 595rwtq.
but i left alot on the table i feel cause my bottle pressure on that cold january day was 720psi.
car was semi tuned using ls1edit and and runnin a bit lean on the juice...around 11.8 to 12.0.
mods are in sig.
mods are in sig.
