Here it is.Plate system Pricing...
Old 09-21-2005, 10:25 AM
Nitro Dave's Nitrous Outlet's Avatar
Default Here it is.Plate system Pricing...
This is a multi-port discharge plate.This gives you a larger cover area for your nitrous stream which will eliminate distribution problems seen in most ls1/Lt1 based plate applications.
These are introductry prices.So pricing may change in the future.
The COMPLETE SYSTEM will come complete with a 10lb bottle with high flow 45 valve,Microswitch,wiring harness and relay,main feed line,stainless steal quick release bottle brackets,300 Hp lifetime warrenty solenoids,Nitrous Plate,oil ring gasket,throttle linkage spacer,jetting from 35-150,hoses,bolts,and fittings. All this for 650.00
CONVERSION KIT- Comes with the plate,Oil ring gasket,Throttle linkage spacer,Bolts,Fittings and Jets. Cost...225.00
These should be ready to ship before the end of this month(September).
We are now taking orders.These are not on the web site at this time so you will need to call in at 1-866-648-7637
Thanks
Dave
Dave
Old 09-21-2005, 10:31 AM
99Ws6TransAm's Avatar
So how much for the plate and whatever id need to hookin in my wet kit i have already? Id like to do this instead of my shark nozzle.
Old 09-21-2005, 10:33 AM
The conversion is 240.00
Old 09-21-2005, 11:54 AM
Elite_Hot_Rod's Avatar
$240.00 is pretty pricey for something doesn't come with jets and hasn't proven itself yet. If you want to sell it you need to come way off that price.
Old 09-21-2005, 11:59 AM
PAGregSS's Avatar
Crap, that's a lot more than I was hoping for the conversion kit. I guess I'll have to do a nozzle setup after all.
Old 09-21-2005, 12:01 PM
Little to much for me right now as well... Crap
Old 09-21-2005, 12:04 PM
Sorry guys.
This thing has everything so It just simply bolts on.The jets from your single nozzle NX kit will work in this plate.Our plate is not just a bare plate like the competitio.This is why we call it a conversion.It uses a ole ring seal.Not a paper gasket.It also comes with the bolts,The throttle cable extention and fittings.
The competition sales a bare plate for 175.00...Our desighn and completeness cost money..
Thanks
Dave
Old 09-21-2005, 12:06 PM
Worm's Avatar
I replied to your PM Dave. Let me know on that dry setup.
Thanks
Old 09-21-2005, 12:50 PM
I fully understand that this is a direct drop in replacement Dave but it's still to pricey. If it were closer to the competitions $175.00 it might make it worth looking into but at 1/3rd more cost and with 0 info on how it will perform in the field all I can say is good luck.
Originally Posted by Nitro Dave's Nitrous Outlet
Sorry guys.
Thanks
Dave
Old 09-21-2005, 12:51 PM
TS6
TS6's Avatar
Could you PM me a price with the conversion and 2 new solenoids for my wet system please? And I can use the jets from my shark nozzle, correct?
Old 09-21-2005, 12:58 PM
Restricted User
CAT3's Avatar
Dave...I am guessing it will use the same jetting pattern as the single nozzle since it should be based off of psi vs. psi (flow of N vs flow of F)?
Do you have pics of this mounted? Please post if so.
This might make for a nice 3rd Stage....after upgrading to a -6 Main Line, and some new NX Anodized custom colored Solenoids. So, will wait til the noids can be ordered in different colors to make that step.
Old 09-21-2005, 01:34 PM
Brains's Avatar
Pics are in this thread:
https://ls1tech.com/forums/nitrous-oxide/377819-new-ls1-lt1-plate-systems.html
Old 09-21-2005, 01:48 PM
Closed ex-Sponsor Account
NXRICKY's Avatar
I will take your custom noid order today.. Which color would you like..
Ricky
Old 09-21-2005, 02:14 PM
gregs99form's Avatar
Is this the NX plate? It's kinda funny NOS has a plate just like this one.
Old 09-21-2005, 02:30 PM
NXRICKY's Avatar
Nope NX does not make any plates for EFI except the 4.6 Mustang..
Ricky
Old 09-21-2005, 03:01 PM
Look at NOSs plate again..Its not like this one. WE have had this drawn up for over 6 months now.Im just now putting it on the market.This is our plate.NX does not make this for us.
Dave
Old 09-21-2005, 03:31 PM
Lets put this into perspective here.
You get
1 billet plate,
1 factor o'ring,
1 linkage extension bracket.
3 stainless steel bolts
and the inlet fittings.
240.00
A carberator plate kit we sale from NX is.
1 billet plate
1 gasket
4 bolts
2 inlet fittings
jets and the small little hardline.
177.00
NX builds thousands of these plates a year which means they can buy and sell cheaper.
Unfortintly we are not a manafacture and can not buy and sell in the quanity that is needed to get these cheaper. However do to the unbeleivable responce that I have reveived from emails,pms and phone calls about this system I will jump out there and order more units so that we can get them cheap enough to include the jets and sell the conversion for 225.00.
Remember I am not a nitrous MFG but I want to give people the trickest stuff out there at the best price my buying power will allow.
Thanks for the feed back. Keep them comming.
Dave
Old 09-21-2005, 03:58 PM
Thanks
Travis,
Back at you.
Dave
Old 09-21-2005, 08:19 PM
trinijoee's Avatar
You get
1 billet plate,
1 factor o'ring,
240.00
Will the conversion fit the C5? Of course the C5 will not be using the linkage extension bracket. Is the the price the same for the C5?
Old 09-21-2005, 11:02 PM
stanley's Avatar
what does the LT1 plate look like? can i see pictures of it?
