FPSS, fuel pressure gauge, and wet kit all at once???
Old 09-21-2005, 07:41 PM
Zeus's Avatar
Default FPSS, fuel pressure gauge, and wet kit all at once???
I got a little ahead of myself over the weekend and ordered a Dynotune wet kit, FPSS, and fuel pressure gauge. I got the pressure gauge today and started hooking it up when I realized that all three hook up to my car's one schraeder valve. I know that people who use a fpss and a wet kit usually hook up a 'Y' or 'T' off the valve, but I've never heard of anyone running all three at once. Do they make three post adaptors? Should I run a "T" into another 'T'? Should I ditch the FPSS and just run the fuel pressure gauge and wet kit of a 'T'? Any help's appreciated.
Old 09-21-2005, 07:54 PM
GM Muscle's Avatar
Go back to Dynotune's site and look under gauge adapters. You'll find a -4an manifold with two 1/8" NPT ports. It should work perfectly and look real clean.
Old 09-21-2005, 08:19 PM
BlownChevySS's Avatar
What kind of gauge did you get?
Old 09-21-2005, 09:04 PM
Zeus's Avatar
so ditch the FPSS, and run the kit and pressure gauge off the adaptor hooked to the schraeder?
Old 09-21-2005, 09:07 PM
Zeus's Avatar
2 1/16" autometer carbon fiber electric
Old 09-22-2005, 08:32 PM
GM Muscle's Avatar
No the adapter has an inlet, outlet, and two ports. So you can run your fuel line, FPSS, and gauge sender all of one manifold.
Old 09-22-2005, 08:45 PM
Zeus's Avatar
ok thanks, i couldn't see the outlet on the back side of the adapter so I thought there were only two 1/8" NPT outlets.
