top gun solenoids
Old 09-24-2005, 08:58 PM
77vettejeff's Avatar
Default top gun solenoids
Does anyone know where I can get tech support for top gun components? Does anyone have a wiring diagram for top gun solenoids? I have some used ones I need to test. One solenoid has two red wires and the other solenoid has two black wires. Also there is no part number on the labels and no ID for fuel or N2O.
Old 09-24-2005, 10:35 PM
LS1TECH Sponsor
DynotuneN2O's Avatar
The fuel should be the one with red wires
Nitrous black wires. put 12v on them see if they click. pressure testing would be best.
Dan
Old 09-25-2005, 09:06 AM
thanks, after cleaning, I definitely will test under full pressure and filtered.
Is Top Gun out of business?
Old 09-25-2005, 09:44 AM
NitrousDirect's Avatar
I second Dan's information.. be sure to test them too
Old 09-25-2005, 07:19 PM
turborail's Avatar
Top Gun is out of business. You don't need a wiring diagram because there are only two wires on each solinoid and it doesn't matter which one you use. One goes to 12volts and the other goes to ground. Simple. The guy who started Top Gun was one of the two guys who started Nitrous Express. Nitrous Express has advanced a lot in the last few years but when they first started they where basically exactly the same as Top Gun.
