Noob to Nitrous, help with plate
Old 09-27-2005, 12:33 PM
waltsfastz's Avatar
Default Noob to Nitrous, help with plate
Ive ot some plans this winter for my Z. As of now I have a fully forged 383 stroker and went a best of 11.68@116.89. I have a NOS wet kit with a NX plate. I have heard that the older NX plates are only good for around a 175 shor because of its small holes on the jets. IS ithis true or just a myth?
Old 09-27-2005, 01:24 PM
NXJeremy's Avatar
What plate is it exactly? NX does not make a plate for LT1 (I'm just guessing that your 383 is an LT1 since it is in a 96 F-body). With some more info I could possibly give you jetting, and it should be able to go quite a bit higher if it is an NX plate.
Old 09-27-2005, 07:29 PM
waltsfastz's Avatar
The guy I bought it from said it was a NX. IT is a plate with 2 brass tubes with 3 holes drilled in each side of the tube(1 for each butterfly) One tube is located about center of the bore and the other is ocated at the very top of the bore. I can get some pics tommorow if that would help
Old 09-28-2005, 09:00 AM
NXJeremy's Avatar
Yea, it would help to have pictures if you have them. It sounds like the NOS LT1 plate from what you are descibing, but then again we have made a lot of custom plates for customers so it could possibly be a hand-made plate that was built for a customer.
Old 09-28-2005, 09:09 AM
Nitro Dave's Nitrous Outlet's Avatar
Im pretty sure that that is a nitrous works or NOS plate.
Dave
Old 09-28-2005, 12:33 PM
waltsfastz's Avatar
Hereis a link
http://memimage.cardomain.net/member...71_74_full.jpg
http://memimage.cardomain.net/member...71_75_full.jpg
Old 09-28-2005, 12:40 PM
NXJeremy's Avatar
Thanks for supplying the pics, but unfortunately I can't be of much help. That is definately not an NX plate. Maybe Nitro Dave can help with figuring out what plate it is and what the jetting would be. Sorry.
Old 09-28-2005, 01:03 PM
Sorry.I also do not know who made that plate.However I would suggest looking into our new LT1 plate.The spray distribution desighn will be much better.It will be available in about a week.
Thanks
Dave
Old 09-28-2005, 07:21 PM
waltsfastz's Avatar
Thanks for looking fellas. How big of a shot can you put through the new LT1 plate? I hope to stop at a 250 shot.
