Nitrous solenoid getting hot.
I installed a NX kit and the nitrous solenoid is getting real hot. I have it ground at the same place the fuel solenoid is, and its not hot at all. I also have the purge solenoid grounded at the same spot as well. I disconnected the solenoid and it remaind hot then I disconnected the power to the purge. Then it finally started to cool down. I dunno if that had anything to do with it or not. The purge solenoid was a little hot as well, but not as hot as the nitrous solenoid was. Any ideas?
Originally Posted by JoeyGC5
Where did you mount the solenoids at? Unless there is some way you wired the nitrous solenoid to a more constant power than the others, motor heat would be my guess.
Originally Posted by Nitro Dave's Nitrous Outlet
Thsi sound like a bad ground.Either clean your grounding surface better or find a new one.Also make sure all your wires have good connections.Then check your wiring.If ITs any of the baove it will smoke the solenoid.
Dave
Dave
We had the car running for less than 30 sec. and the fuel solenoid was cold. The nitrous solenoid got hot. I would think if it was engine heat both solenoids would get hot. It was so hot it was hard to keep your hand on it.
Chad, I am willing to bet it is the ground as Dave mentioned, and as we discussed. Its just strange the other solenoids were ok, and the solenoid even open and closed.
Ok I cleaned the area I used to ground the solenoid, and I even gave it its own connection. I tested the system and both solenoids are working fine, but the nitrous solenoid is still getting very hot. I have the braket mounted to a bolt off one of the coil packs, where mines located. I have never had a problem with my solenoid getting hot. The solenoid in question got so hot lastnight you could barely touch it, yet the fuel solenoid was fine. The nitrous solenoid must be bad for it to get that hot.
Like I said in my first post, as I was testing the system the fuel solenoid was cool and the nitrous solenoid got hot, and the hood was up, and the engine was on for maybe 30 seconds.
A wiring issue on my part? I mean wiring a solenoid is a no brainer. I have done my fair share of nitrous installs. This is the first time a solenoid has gotten this hot on me, and this is a brand new NX kit.
Sorry.Not trying to offend you.Im just saying in the past.Problems like this have always traced back to wiring.In some cases a bad activation switch. After rereading and thinking more.Since only the nitrous solenoid is getting hot and all grounds check out good,wiring connections check out good Im stumped...The only thing I can think of is maybe the coil is defective.Call Josh at NX and get a RGA number.THis way you can send the solenoid in for inspection.Let him know that I talked to him about you already.When Ricky gets in today I will direct him to this link.
Thanks
Dave
Thanks
Dave
I wasn't offended at all. I was just wanting to make sure I didn't misunderstand you.
Thank you for the help. I'll get ahold of the solenoid by this weekend, but I'll call Josh soon. Thanks again.
