new to n.o.s please help me with a safe shot of nos and what to do!?!?
well there are my specs....please tell me a very safe shot what gears to hit it in and what i will need with it?? do i always have to run race gas timeing ecttt...
VERY safe? 100 - 125 shot. You can easily do a 150 shot safely too. You can hit it in any gear as long as you have traction. I would not spray below 3 k RPM unless you are using a progressive controller. If you advanced your timing with the tune for the cam you might want to look into pulling some. Off the top of my head I would look for a window switch, fuel pressure safety switch, colder set of plugs (TR-6), and a bottle heater if you go with a wet kit. Since you already have a cam it might not be a bad idea to do an upgraded fuel system, like a Racetronix kit.
Matt
Matt
No nitrous ha tony lol....and you want to take out 2 degrees per 50hp and if your going to leave it on pump gas do no more then a 125 and take out 8 degrees...All you had to do was ask me tony and i would help you...
