Safe bottle pressures
I run mine at 1150, but this is a dry set-up, so it's like putting larger n2o jets in. Now on a wet kit jets are static so you should stay with what the manufacturer indicates. the reason being, is to keep in the optimum a/f ratio, as wet has no way to compansate for increased n2o flow (adding extra fuel). Dry compansates through the computer for extra fuel.
Robert
Robert
Originally Posted by KCS
I knew all that, I just didn't know if I could go over 1050 and stay safe or blow my intake off with 1150. Thanks for your help, though. BTW, its a TNT F2.
1150 here too, you will be fine.
If I understand your question right the pressure has nothing to do with damaging the engine except if it results in an incorrect AFR. The pressure effectivly is gone once the nitrous leaves the nozzle and enters the intake stream. Higher pressure simply pushes more nitrous into the engine than does a lower pressure with the same jet size.
Assuming you keep the same nitrous & fuel jets the higher the nitrous pressure the leaner you will be and the lower the pressure the richer you will be.
So if you check the AFR at 1,000 psi and you are at 12.0 for example. Then you run the car at 1,100 you will be leaner than 12.0 and if you run at 900 psi. you will be richer than 12.0.
A buddy of mine had his Z06 in the sun and bottle pressure went o like 1500psi, good thing it was a dry hit. On his run he had his best ET ever, it was like up sizing the jets big time.
KCS, I did not assume that you didn't know the info, but rather included it all for those reading along that may not have known everything.
Robert
