100 shot with 4.11s what you guys think?
OK i am runin full bolt ons and 100shot. I went 12.5 @ 114 before i put in a 9in with 4.11's, textraila clutch, and some et streets. I droped my 60' from 2.0 to a 1.7 and now i went 12.3 @ 113. What is happenin now i have to shift into 5th at the end. Is this a good time for a 100shot i wanted to be 11's. Also is it bad that when i shift into 5th that i am off spray and then my window switch turns it back on for the rest of the quater (only 20' or so) thanks alot guys
That's what I say also, get a taller tire (29")? Just knocking your 60'er down like you did should have given you about a .450 gain. Some more seat time may be the answer also. Yep, you do not want to go into overdrive, and that's probably your biggest issue. Some of the guys running 4.10's will chime in and get this figured out.
Robert
Robert
thanks guys i shift at 5800 i am still on teh stock rev limiter and they are et street radials 275-40-17's. I am goin to get a guy to use hptuners and adjust my rev limiter what should i set it to? thank you so much again!
8 SEC SLOPPY SHOT!!!
A 100 shot should be no problem.Just get your rev limter rasied because nitrous is going to make it rev a bit more.I ran a 100 shot back in the day on 4.11 gear and i wasn't a problem at all.Hell i still run 4.11 gears with a 300 shot Your going to have to get the car to hook up.Might consider et streets
That might be the difference then. I shift over 1000 rpms higher than you I say get it raised. Should be good even on stock heads/cam to go to 6200-6400 as lon as it still makes power there.
