welding fitting on stock rail
Old 10-23-2005, 10:45 PM
JRick212's Avatar
Default welding fitting on stock rail
I need to weld a -4an fitting to the stock fuel rail on the passenger side on the back of the rail. However I am not sure what the stock rails are made of and where to get a fitting that will work. Anyone done this?
Old 10-23-2005, 10:53 PM
Elite_Hot_Rod's Avatar
Might help if you explain what it is you are trying to do.
Old 10-23-2005, 10:56 PM
Nitro Dave's Nitrous Outlet's Avatar
PM sent.
Old 04-30-2009, 02:29 PM
chpmnsws6's Avatar
Has anyone figured out what it takes to weld these?
Old 04-30-2009, 02:50 PM
jmill96Z's Avatar
You can have a fitting silver soldered on the rail
Old 05-03-2009, 02:26 PM
chpmnsws6's Avatar
Just silver solder a brass or steel fitting to it?
Old 05-04-2009, 12:38 AM
jmill96Z's Avatar
We did steel to my old LT1. just get a -4 to NPT fitting, and cut off the NPT portion. Then silver solder the base to the rail
