Which Nitrous Kit?
Which Nitrous Kit?
I am considering a new or used dry nitrous kit for my 01 Z28. I know nothing about this stuff and would really like to learn and possibly purchase one later this year. What are your suggestions for complete dry kits? Looking at around 100hp to 150hp shot.
We have a dry kit that will work for you. Here is a link to it:
http://www.harrisspeedworks.com/shop...cat=305&page=1
It comes with instructions and a lifetime warranty on all the components. Now, if you are looking to spray more then a 100 shot dry you'll need to upgrade your fuel system (Racetronix pumps are nice) and there is a very good possibility that you will need to upgrade your injectors also (which you'll need a PCM tune for the injectors also). If you are thinking about that size shot you might want to look at a wet kit as it could be less expensive in the long run. Don't get me wrong, the dry kit will be okay, it just depends on how you want to do things. I also suggest a window switch and fuel pressure safety switch with a dry kit, and a bottle heater in addition to those items if you decide to go with a wet kit set up.
Matt
Matt
FYI... We are giving a way a FREE single nozzle dry kit this month.Check out this link for info.
https://ls1tech.com/forums/nitrous-oxide/393700-free-single-nozzle-dry-system.html
Thanks for the input. Maybe I will get lucky and get the free kit. If not I am looking at the latter part of the year, or beginning of this year unless someone has used one at a knock dead price.
LS1TECH Sponsor
All the kits above are good choices.....Another great option is the DynoTune Kit at $349
http://www.dynotunenitrous.com/store...?idproduct=118
Comes with our complete instructions book!
Dan
Dan
