BMN Window Switch Just Went Dead???
Old 10-28-2005, 04:13 PM
Blown Interceptor's Avatar
Default BMN Window Switch Just Went Dead???
Just came home from the dyno, did one pull with 150 shot. I changed the turn off setting, then all of a sudden the switch would not work anymore. The red light won't come on, it wont spray, nothing. I checked all the connections, they are fine. Went through my fuses, all check out ok.
Any ideas???
I am at a loss.
Thanks,
Jason
Old 10-28-2005, 04:49 PM
Nitro Dave's Nitrous Outlet's Avatar
Jason, The unit was working one minute and not the next? Did you change anything.
Dave
Old 10-28-2005, 04:56 PM
Dave
Correct, the only thing I changed was the nitrous shut off dial.
Old 10-29-2005, 08:04 AM
XTrooper's Avatar
Make sure neither of the dials are "between" the notches/settings. In other words, make sure you hear/feel the click so that you know it's not in between rpm points.
Also, did you use a tester to see if the "hot" wire leading to the switch actually has power going to it?
Old 10-29-2005, 09:23 AM
Made sure the dials were in the correct place, and not in between.
No, I don't have a tester...I guess I need to get one. I am gonna try replacing the relay, maybe that could be it???
Old 11-01-2005, 07:12 PM
Dave
Dave,
Have you known of any of these controllers going bad? The red light comes on, but it is very dimm. When I blow on the unit, the light goes off, then comes back on when I blow on it again. Could the unit have gone bad?
Thanks,
Jason
Old 11-01-2005, 11:17 PM
Jason. That is crazy.LOL It sounds like the unit has went bad. I would get with BMN and send it back to Bill for him to check. Call me if I can help.
Dave
Old 11-02-2005, 09:27 AM
Dave
Dave,
They don't have a phone number on their web site...so I sent them an email. I'm sure they get a ton of emails a day, I hope they respond soon with what to do.
Thanks for the help!
Old 11-02-2005, 10:39 AM
I just called his cell phone and left a message for him to call me. Pm me your info and phone number so I can have him call you. I will help you out so This goes as quick as possible. How long have you had this unit?
Dave
Old 11-02-2005, 01:28 PM
PM sent. Thanks alot for your help!
I thinks its been less than a year, maybe 8 months or so.
