predator tuner and nitrous???
I understand that the tunner advances timing but how much?? and i have the ability to retard it also. but on the tuner it is in a %, and I know I should retard it by 6 degrees for a 100 shot. has any tried this at all??
Moderator
Predator pushes +6 degrees when you "install performance".
You can take back out 3 degrees by the settings.
A better bet is probably to get the diablosporttuning.com
utilities that reflash the Predator and make it modify the
spark & fuel relative to "found settings" rather than the
"canned tune".
Leaving stock timing and fuel (which is naturally rich from
factory) might be a better idea than running the canned
tune on the bottle.
"canned tune".
tune on the bottle.
Im going to be in the same boat. I have my Predator set at -2% for daily driving as it is and I belive at wot im around 27 degrees of timing. Would that be ok for a 100shot or should I pull more?
