New time on 150 shot??? - LS1TECH
Thread Tools Search this Thread
Old 11-05-2005, 11:44 AM   #1
PERFECT Z28's Avatar
Default New time on 150 shot???
Since I last ran my car at the track I had the following added to the car...
* VIG3200 and trans cooler
* BMR TA relocation kit
* BMR LCA relocation brackets
* BMR tubular LCA's
* BMR tubular subframe connectors
* FORD SVO 30# injectors
* had the car dynotuned
* and I upped the N2O from 125 to 150 shot
...any estimates on what I should be running?
I was using MT ET STREETS on 16" WELD racing rims when I ran in AUG and I will use the same set for the next visit to the track.
PERFECT Z28 is offline   Reply With Quote
Old 11-05-2005, 01:01 PM   #2
Caribe's Avatar
I'm guessing around 10.8-10.9
Caribe is offline   Reply With Quote
Old 11-05-2005, 01:11 PM   #3
strokedls1's Avatar
I would say around 11.2 unless you had a lot of tire spin before.
strokedls1 is offline   Reply With Quote
Old 11-05-2005, 02:01 PM   #4
Quote:
I ran on MT ET's the time before, I had 0 tire spin...those things GRIP.
Old 11-05-2005, 02:12 PM   #5
beardWS6's Avatar
11.0-11.2 sounds about right!
beardWS6 is offline   Reply With Quote
Old 11-05-2005, 02:18 PM   #6
I was thinking deep 11's...Precision Industries tells me I should see a .3 to .5 with the addition of the VIG3200.
It sure would be nice to be knocking on 10's door w/o H/C or even a cam.
Old 11-05-2005, 03:18 PM   #7
mike c.'s Avatar
just go to the track and findout.
mike c. is offline   Reply With Quote
Old 11-05-2005, 03:20 PM   #8
Quote:
I will as soon as finish rebuilding the tranny - replacing output shaft tomorrow.
I'm just looking to see what times I should be trying to compare my car's performance to.
I won't have a chance to race it for like 2 weeks...next weekend is the LS1TECH event at S.A.R.!!!
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
