boiling water to heat n20
Old 11-12-2005, 12:53 PM
Insanekamel's Avatar
Default boiling water to heat n20
Boiling water to heat n20 is safe right.. as long as i dont let the pressure get way to high?? i only got 3 lbs in the bottle left and wanted to use some of it before the weather goes south...
Old 11-12-2005, 01:07 PM
JustAnIlluzion's Avatar
im not sure about boiling water, i would just run really hot water in the laundry room sink and let the bottle sit in it for 20 minutes b4 heading out
Old 11-12-2005, 02:26 PM
JamesO WS6's Avatar
I've always used hot water, never boiled it. If your really wanna boil it I would keep an eye on the pressure gauge. And you shouldn't have any problem. If you dont have a gauge on your bottle then I would defintly steer clear of boiling water.
Old 11-12-2005, 02:32 PM
rdeterman's Avatar
i would also not use boiling water... plus it would make your nice stickers fall off jk
Old 11-12-2005, 05:35 PM
red fury's Avatar
yeah, warm-hot water will do the trick
Old 11-13-2005, 11:19 PM
Nitro Dave's Nitrous Outlet's Avatar
just use Hot water but you are waisting your time with three ponds. You might get a small hit when you use it and then its over.
Dave
