Dry Kit less danger?
Board Certified Idiot
well both are dangerous if not set up correctly.. DRY u tend to go RICH WET is LEAN allways better to go RICH then LEAN i say .. with wet u just need a good SOLENOID .. if ur system is goin to be set up correcty then you should have no worries plenty of ppl using DRY 100shots on there motor around here.. i think wet is less stress on the motor to haha just my opnion
wet kit
Wet kit in my opinon easier on motor, although these intakes are not ment to flow fuel, Wet kit your not relying on your injectors, makes easier to tune.
Originally Posted by Nitro Dave's Nitrous Outlet
You will get mixed emotions on this. I will say a dry system is easer to use for less money. A wet system will give better performance.
Dave
Dave
Robert
