Which TPS switch should I go with?
Ok well I just installed my electric water pump and the WOT switch I got from dave doesn't fit anymore. With switch is the most reliable, easiest to wire up, and configure.
Closed ex-Sponsor Account
Take a look at ours. No set screw to adjust, just push a button and you're done.
http://www.harrisspeedworks.com/shop...age=1&featured
Thanks,
Matt
Thanks,
Matt
Originally Posted by Nitro Dave's Nitrous Outlet
We carry the ZEX and the NX one. I would recommend using TRick window switch and selling the window switch you currently have. This window switch is a digital unit. It has a dual window switch with TPS and gear lock out features. They are 129.00
Dave
Dave
I seem to be getting good traction with my tire's in first gear on spray right now(mt et street radials). I'm currently using my timing tuner as my window switch and dont really think I need gear lock out. How easy is it to adjust the zex unit compared to the other brands. Thanks in advanced.
-William
-William
The Zex TPS actually holds the pattent to the adjustable TPS. They offer a top quality unit. We sell them for 75.00.Its well worth the 75.00.
Here is a link to there web site so you can check it out.
http://www.powerandperformancenews.c...ROUSCOMPONENTS
Dave
Dave
LS1TECH Sponsor
Another couple of options for you: The Dynotune TPS switch at $69
http://www.dynotunenitrous.com/store...?idproduct=105
Or our Dual Stage TPS / RPM Window Switch
http://www.dynotunenitrous.com/store...?idproduct=194
Dean
Dean
i have been using the one from harris speed works and have been very happy with it. it's very easy to hook up and to set.
jeff
jeff
Good to hear Jeff!
jeff
jeff
