What RPM are you guys spraying to??? 4L60E ONLY!!!!
I would like to know on and off RPM's..... and are you spraying through the shifts....
Im trying to decide my turn off point for the spray....
My car is an auto 4l60e, and id like to set the shift point in the tranny only once....
Just trying to find a happy medium between turn off RPM for the spray and maximum shift RPM in the trans.....
thanks
thanks
All depends on if you want to spray through the shifts.I for one don't want to, i'm
trying to keep my tranny for a while so i decided not to. Alot of people spray through
and still have thier A4's, i've taken out almost all T.M so i'm not gambling.
Turns on @3000 off at 5800 shift @ 6000 1-2 / off @ 5800 shift 5900 2-3. First to second is perfect no lag, but from second to third you can really feel the NOS turn off then it shifts and back on again. I tried adjusting shift mph & rpm for 2-3 shift, but I don't have it dialed in as good as the 1-2 shift is. The new converter is going in soon so I will probably have to start all over again with adjustments then I will try to get 2-3 dialed in like 1-2is.
Restricted User
I sprayed out of the hole, and thru the shifts (no WS), trans programmed to shift at 6600 and rev limit was 6950. Worked quiet well.
Stock bottom, TSP 231/237 Cam, TR Pushrods, PP Springs on old-*** PP5.3L heads, JetHot LT's and TD's.
Now, will be learning to shift my RMVB Ross Braked TH350, then will go back to spraying.
well i bring my bottle in at 3000 and have the off pill at 6600. but i am notorious for short shifting the car. im a 3600 stall with 3.73. so i spray threw the shifts. and u dont have to worry bout the tranny if its built right. im mid 1.4 60s and fixn to go 1.3s. so just get the right vertor and good tranny and hose the hell outta it. good luck my limiter is at 6600
